Home » Sponsored » Pi Speakers » Theater 4Pi plans - 3/4" material ?
Theater 4Pi plans - 3/4" material ? [message #35443] Tue, 12 March 2002 08:02 Go to next message
TOttman2 is currently offline  TOttman2
The Theater 4 Pi plans seem to give outside dimensions... is 3/4" material assumed ? or are these measurements inside dimensions?
Thanks...
Tom
yes... [message #35447 is a reply to message #35443] Tue, 12 March 2002 09:23 Go to previous messageGo to next message
trancemitr is currently offline  trancemitr
Those are outside dimensions using 3/4" material.
Kevin
Re: Theater 4Pi plans - 3/4" material ? [message #35448 is a reply to message #35443] Tue, 12 March 2002 09:23 Go to previous message
Hi Tom,
The dimensions are outside dims. and the plans assume a 3/4" wall thickness. So if want thicker walls you have to go out(larger) or risk changing the cabinet loading characteristics. One thing the plans don't show but Wayne has said he sometimes uses, is a cabinet base riser. I put a 1 and 1/2"high ring of left-over Baltic birch screwed/glued to the base which lifts the horn up to about seated ear level which helps with the highs,IMHO. I think if I were to start over I'd make the ring(actually a rectangle) 2" or maybe even 3" tall.This riser helps with the appearance as well- it's a common feature on cabinets of all types.
Good luck with the assembly- your in for a treat on completion!
Garland
Previous Topic: Listening to Theater 4's and Wayne's Bracing Photo
Next Topic: 2426 horn loading questions @ Altec 511 B, 2370 comparisons
Current Time: Wed Nov 04 04:30:43 CST 2026
