Home » Sponsored » Pi Speakers » ballpark Eq/comp for PV CH2?
ballpark Eq/comp for PV CH2? [message #35434] Mon, 11 March 2002 11:00 Go to next message
freddyi is currently offline  freddyi
Hey Wayne and group
graphed Eminence CD-8 on Peavey CH-2 - mic may have been too close as it showed very level/smooth FR to 12.5Khz rolloff point both on and ~20 degrees off axis - 'ears' say its subjectively dull/unbalanced compared to 'old school' horn
when using w. typical 97-99dB 15" direct radiator - what might be workable cap bypassed series pad starting point? - didn't have much luck trying a couple of value caps across series leg of L-pad although Peavey horn designer suggested that method
Freddy
Re: ballpark Eq/comp for PV CH2? [message #35436 is a reply to message #35434] Mon, 11 March 2002 12:43 Go to previous message
I have no experience with either the CD-8 or CH-2, but I can certainly give you copies of my schematics for 800Hz and 600Hz crossovers. Both have compensation for rolloff at higher frequencies. They're set to begin augmentation a little sooner than the 1.6kHz crossover because the response band is shifted down when using the larger horns that these crossovers are designed for. I'm not at my office right now, but I'll send 'em to you if you're interested. Just let me know.
Previous Topic: What is the differance between JBL 2226H and 2226HPL?
Next Topic: Spice revisited
Current Time: Wed Nov 04 05:55:02 CST 2026
