Home » Sponsored » Pi Speakers » pushed in tweeter
Re: pushed in tweeter [message #35427 is a reply to message #35422] Mon, 11 March 2002 06:42 Go to previous message
You can also try it with duct tape.
Another solution is to dab a *tiny* bit of hot melt glue on the end of a needle, let it dry on the dome and then pull. I've fixed some badly crumbled titanium domes like this, but if you apply too much glue, you're in trouble.
As a last, last resort... When all else fails... You can poke a needle into the dome sideways and then pull it out. The tiny hole won't really effect the operation of the tweeter.
Adam
Previous Topic: What are you're views on re-coning,re-foaming
Next Topic: Portable system help please
Current Time: Wed Oct 14 21:54:31 CDT 2026
