Home » Sponsored » Pi Speakers » Impossible enclosure design?
Impossible enclosure design? [message #35176] Sat, 23 February 2002 10:11 Go to next message
AJ is currently offline  AJ
Hi,
I'm trying to build a enclosure for an almost 10" driver with hard suspension. I'm a complete novice so mabey it's complete impossible I'm trying to do. I thought the driver was most suited for a closed encloure or like someone suggested a open baffle.
specs from the driver :
Almost 10"
Qts = 0.9
vas = 85 liter (Not complete sure of this spec....)
Fres = 62 hz
If I run this in pi-align I get :
3.1 c.f enclosure
26"*17"*11" enclosure
Port dimensions (cilinder) = length .87" diameter 1.66"
My question, is this possible? What can I expect from the bass?
Thanks for your reply,
AJ.
Re: Impossible enclosure design? [message #35177 is a reply to message #35176] Sat, 23 February 2002 10:26 Go to previous messageGo to next message
I forgot some paramaters :
qms = 9.5
qes = 9.99
Re: Impossible enclosure design? [message #35182 is a reply to message #35177] Sat, 23 February 2002 15:47 Go to previous messageGo to next message
I think there's a mistake in the speaker parameters you described. It would be rare to find a motor having Qes of 9.99, and you wouldn't want to use it if you found one.
Re: Impossible enclosure design? [message #35191 is a reply to message #35182] Sun, 24 February 2002 01:36 Go to previous messageGo to next message
It is a old full range driver. I know these spec's are not normal, but I (think) they're pretty accurate. If I really want to use the speaker, what would be the best enclosure?
AJ.
p.s : The qes must be 0.99 isstead of 9.99 of course....
Re: Impossible enclosure design? [message #35202 is a reply to message #35176] Sun, 24 February 2002 18:58 Go to previous messageGo to next message
Rudi is currently offline  Rudi
Has it got a paper edge.
Open backed cabinet suitable for paper surround drivers [only for guitar]
Infinite Baffle also might be okay if it's a fullrange
Re: Impossible enclosure design? [message #35206 is a reply to message #35202] Mon, 25 February 2002 02:25 Go to previous message
Hi,
Yes, it got a (doped) paper edge witch is extremly stiff.
Thanks,
AJ.
Previous Topic: Not all same diameter drivers have the same cut out diameter
Next Topic: Hey Garland!
Current Time: Sat Nov 14 13:32:56 CST 2026
