Home » Sponsored » Pi Speakers » Impossible enclosure design?
Impossible enclosure design? [message #35176] Sat, 23 February 2002 10:11 Go to previous message
AJ is currently offline  AJ
Hi,
I'm trying to build a enclosure for an almost 10" driver with hard suspension. I'm a complete novice so mabey it's complete impossible I'm trying to do. I thought the driver was most suited for a closed encloure or like someone suggested a open baffle.
specs from the driver :
Almost 10"
Qts = 0.9
vas = 85 liter (Not complete sure of this spec....)
Fres = 62 hz
If I run this in pi-align I get :
3.1 c.f enclosure
26"*17"*11" enclosure
Port dimensions (cilinder) = length .87" diameter 1.66"
My question, is this possible? What can I expect from the bass?
Thanks for your reply,
AJ.
Previous Topic: Not all same diameter drivers have the same cut out diameter
Next Topic: Hey Garland!
Current Time: Sun Oct 18 16:03:53 CDT 2026
