Home » Sponsored » Pi Speakers » How do you guys do your measurements??
Re: measure where the rubber meets the road [message #35161 is a reply to message #35153] Mon, 18 February 2002 19:15 Go to previous messageGo to previous message
Robert Hamel is currently offline  Robert Hamel
Hello Sam
That's about what I have been doing. Just looking for a better way. You are absolutely correct about that window being big. I had the driver in with no fiber glass and the back panel just laid in and the first cut sounded real good. Didn't measure as good as it sounded but I was sure happy. I am trying to determine if I have a room issue or a sensitivity issue. My cabinet is tunned for 50 Hz and crosses over with a L/R at 250 hz so at 250HZ I am down 6 db and the peak is right smack in the middle of the too!!! I already tried the woofer full range and the peak is still there so I am leaning towards the room. I have not moved it yet as that is the next step. This sure does keep you thinking. Thanks for the encoragement.
Previous Topic: another horn hater www.audioperfectionist.com
Next Topic: 800hz ksn1188 fourPi alpha crossover an horn
Current Time: Thu Nov 05 16:54:21 CST 2026
