Home » Sponsored » Pi Speakers » Magnet wire re-visited
Re: Vicarious thrills [message #34954 is a reply to message #34953] Thu, 31 January 2002 18:44 Go to previous messageGo to previous message
IC's are 1 meter Homegrown Silver Lace. The Official Interconnect of Audiogon.
Mapleshade says less than 8' sounds bad so I started there. Used to be you wanted to solder your amps output transformer leads to the speaker inputs and have longer IC's. Don't know whose right. I haven't tried short magnet wires, but will.
All this magnet wire stuff is an attempt to emulate the sound of 47 Labs OTA wire which is a 26 ga heavily teflon coated copper.After 100's of hours of break-in it;s supposee to be very special. $600. Also an Audiogon fave.
The Zobel is still attached with gators but I consider it permanent. I made the mistake of two tweaks at once. The bad effect was the wire, not the network.
Previous Topic: ports and grills
Next Topic: Acoustic filter Q and PiAlign's "Qe"
Current Time: Sat Oct 17 05:23:14 CDT 2026
