Home » Sponsored » Pi Speakers » Attention: If you own JBL 3677S click here
Attention: If you own JBL 3677S click here [message #34932] Tue, 29 January 2002 18:44 Go to next message
I sent for and received (thanks to JBL tech Everett Watts) the specs on the 3677 components. Eight pages worth.
If someone has a scanner and wants to e-mail me a fax number, perhaps they could be posted. Most of it is response curves.
The Thiele-Small for the M-115 woofer are for before and after a power test as follows:
Fs 46, 42
Re 5.3, 5.3
Qms 5.1, 4.6
Qes 0.42, 0.39
Qts 0.39, 0.37
Vas 225L, 275L
Mms 53g, 53g
Cms 222uM/N, 271uM/n
Bl 14TM, 14TM
Rme 37, 37
Sd 845 sq cm, 845 sq cm
Le 1.3mH@1kHz, ditto
Rg 0.91 degC/W, ditto
Rt 1.56 degC/W, ditto
Power test 50-500Hz 40V RMS (250W) Free air for 100 hours
Leap motor constants Krm 8.47mH Erm 0.696
Krm 17.7mH Erm 0.667
The graphs show - 10 dB at about 25 Hz rising to 115 or so and peaking near 120 at almost exactly 1.6kHz with a zoom up after to 2000Hz and then rapidly falls off. Unfortunately, after further review, it seems the graphs were plotted in an 8 cu ft sealed enclosure. Oh well.
There are several graphs of the 2418 horn. One is called EPR Plane Wave Tube Response, one is a waterfall looks like a Melissa, and others. There is a data sheet that reads that freq resp is +/- 1 dB 1000 - 6000 Hz,etc. There are also T/S Parameters for the 2418:
Fs 1000 Hz
Re 3.7 ohms
Ret 8 ohms
Sd 15.5 sq sm
xmax .5 mm
BL 5.0 Tesla
Mms 1.1 gram
Le .08 mH
No 25%
Zmin 5.0 ohms Pe 25 watts into zmin
I hope this helps someone. Ain't the people at JBL amazing!
Good information [message #34933 is a reply to message #34932] Tue, 29 January 2002 20:04 Go to previous messageGo to next message
Thanks very much for the information. I think everyone that bought these JBL speakers from the tent sale appreciates your post a great deal.
Re: Good information [message #34934 is a reply to message #34933] Tue, 29 January 2002 20:08 Go to previous messageGo to next message
It's very cool that they posted xmax.
Adam
Re: Attention: If you own JBL 3677S click here [message #34937 is a reply to message #34932] Wed, 30 January 2002 06:33 Go to previous messageGo to next message
spkrman57
Greetings all, Can any of you math wizards tell me what the efficiency and or sensitivity is on this. With all these specs, I'm not sure if the answer is right in front of me or not. I never said I was a rocket scientist. I don't believe you have to be in this field. (I'm sure it helps though, my basic math is fine, just can't handle multiple equations) Thanks from the math challenged, Ron
97dB [message #34938 is a reply to message #34937] Wed, 30 January 2002 07:50 Go to previous messageGo to next message
250 watts is a 23dB increase over 1 watt, so if the 250 watt measurement maxes out at 120dB, I'd expect the maximum 1 watt SPL to be 97dB at 1 meter. I'm guessing at 250 watts, it is losing 1dB or so to thermal compression so it's 97dB to 98dB at 1 watt / 1 meter. At 500 watts, it probably loses 3dB to 4dB, but thermal losses aren't quite that high at 250 watts. Also note that Bill said the passband average was 115dB, so most of the bass range would be closer to 92dB. Used as a midwoofer in a two-way speaker, you can expect midrange output to be 3-6dB louder than bass below 100Hz.
Re: Attention: If you own JBL 3677S click here [message #34939 is a reply to message #34932] Wed, 30 January 2002 09:52 Go to previous messageGo to next message
spkrman57
Hi again, I am wondering if the spec sheet for the 2418 horn/driver has minimum crossover frequency limit on it. I see where T/S has "fs = 1khz" , I see application puts crossover at 1.2 khz. Usually I double fs to get minimum safe crossover frequency for compression horns. Has anyone put a pi crossover on these?????? Regards, Ron.
Things and stuff [message #34940 is a reply to message #34939] Wed, 30 January 2002 10:32 Go to previous messageGo to next message
Our crossover uses a third-order filter on the tweeter with top-octave compensation. The frequency chosen is where there is DI matching between midwoofer and tweeter. I generally try to make circuits in one series similar to another, so there is some standardization possible. This also gives a nice upgrade path, where you can re-use components as much as possible.
Thanks nt. [message #34950 is a reply to message #34932] Thu, 31 January 2002 06:01 Go to previous message
Robert Hamel is currently offline  Robert Hamel
nt
Previous Topic: Possible use of Lambda woofer in Pi enclosure.
Next Topic: Beta site for midwest gathering
Current Time: Mon Oct 05 15:17:02 CDT 2026
