Home » Sponsored » Pi Speakers » Waaayynnee.... 25 Hz horn sir?
Waaayynnee.... 25 Hz horn sir? [message #34916] Mon, 28 January 2002 15:46 Go to next message
Hehe, does this look about right for a 10 pi with a 25 Hz flare??? :
1600 sq inches (10.66 sqft) mouth area, theoretically should have a flare of 25Hz?
just a normal 2'x2'x4' 10 pi with an extra fold, just like you said.
I could go for a couple of these in my room :P
Are the dimensions right?
p.s. I called the store... My CH-3's won't be in for another two weeks now :(
Adam
Re: Waaayynnee.... 25 Hz horn sir? [message #34918 is a reply to message #34916] Mon, 28 January 2002 16:01 Go to previous messageGo to next message
Just a little bookshelf speaker, eh? [grin]
What you have would certainly have a much lower cutoff peak, and I expect it would be down in the twenties or at least the thirties. Check it out with Hornresp to see its response curve and other properties.
Adam, your CH-3s... [message #34927 is a reply to message #34916] Tue, 29 January 2002 08:16 Go to previous messageGo to next message
trancemitr is currently offline  trancemitr
Adam,
Where are you getting your CH-3s from? I called Music Sound World in Tulsa, and they told me they'd call me when they get them in. I'll be getting kind of antsy if I have to wait 2 weeks.
Kevin
Re: Adam, your CH-3s... [message #34928 is a reply to message #34927] Tue, 29 January 2002 08:31 Go to previous message
I got them from a local dealer. I don't think you'll have any problems. Being in Canada, I get shafted as usual. Peavey apparently only bothers to ship anything up here about once a month, and there's nothing in the warehouses. So now I have to wait for them to send up the next shipment.
Oh well, I took a pair of old home speakers I built and set them on top of the cabinets to get some treble. Sounds worlds better. Really did improve the perception of the bass. Soudns great now. Can't wait to get the horns in there.
Adam
Previous Topic: high Le vs. low Le woofers
Next Topic: Wayne...
Current Time: Wed Nov 04 04:05:25 CST 2026
