Home » Sponsored » Pi Speakers » Four Pi Bass Reflex Driver mix of JBL HF motor & Delta 15 Pro
Four Pi Bass Reflex Driver mix of JBL HF motor & Delta 15 Pro [message #34831] Mon, 21 January 2002 14:09 Go to previous message
anna is currently offline  anna
Hi Wayne. I E-Mailed you last week. Thank you for your response. After looking at your lineup, I think I am interested in the Theatre Four Pi. Can the JBL 2426 be used with the Eminence 15" Delta Pro? Would the balance be OK?
Second Subject. I have a JBL D130 & 075 Ring Radiator. They sit in a falling apart very old HeathKit enclosure. My Paramour easily drives them very nicely to a good ( for me ) level. Does your Professional Series relate at all efficiency ( or soundwise) to my old mono setup? I have loved my D130 over the years. I have had it since 1957. Anyway, I would consider the Pro Series if my Paramours could handle it. I know my old McIntosh 250 amp will. I would appreciate your comments.
Matt Reddington in Dayton
I would appreciate the plans for the Four Pi Theatre speaker.
Previous Topic: Beginner seeks help with “the usual question”
Next Topic: Wayne, bracing restricting port flow?
Current Time: Mon Oct 26 12:43:37 CDT 2026
