Home » Sponsored » Pi Speakers » ARE SCOOP BINS THE BEST FOR KICKIN' BASS
Re: ARE SCOOP BINS THE BEST FOR KICKIN' BASS [message #34776 is a reply to message #34774] Wed, 16 January 2002 15:57 Go to previous messageGo to previous message
Well I disagree. I've used a lot of pro woofers and ive used a lot of woofers like how i described.
You will *not* achieve an f3 of 20 or 25 Hz like you can with a woofer like I mentioned with 99% of all home drivers, including lines offered by Eminence or JBL. I speak from personal experience. Maybe if you can afford absolutely giant enclosures they might work fine.
Most pro woofers run lower Q values and higher fs values to make them effecient. These are not exactly golden parameters for super deep bass response.
Kilomax 18's even in largish ported enclosures won't go flat to 30 Hz. You can get a tempest flat to 20 Hz and it has the excursion to handle it.
Adam
Previous Topic: crossover
Next Topic: Re: All American
Current Time: Mon Oct 26 09:45:48 CDT 2026
