Home » Sponsored » Pi Speakers » initial thoughts on my ten pi's...
ahhh....... [message #34753 is a reply to message #34749] Tue, 15 January 2002 04:39 Go to previous messageGo to next message
Well that's just a stupid on my part then... I didn't notice that part at all. All I saw were sections for higher frequency horns off to the right and I completely ignored them.
I punched in the wood thickness and the woofer displacement and low-and-behold, the numbers match up very consistantly with the proportions now. PIALIGN recommends the same tuning (hmm?) but has a new box volume of 1.79 cuft.
I did indeed plot the 2.2 cuft box in unibox a while ago and things looked good. I just did it again now. Oddly enough, the response curves for the two alignments (1.8 cuft and 2.2 cuft) are nearly identical, but I suppose upon further examination there isn't a *lot* of difference between the volumes. In 1.8 cubes, response is down almost exactly 6 db at 50 Hz, while in 2.2 cubes tuned to the same frequency, response is down about 5 db. So either one seems to work.
I'm glad we cleared that up. It still leaves the excursion issue unexplained, but I'll leave that to rest for now. I don't know. Unibox tells me that the motor will still handle 400 watts over most of the frequency band and you're telling me the same thing, so maybe I'll just shutup.
I'll stiffen up those panels and get everything good to go, and I'll let you know the *finished* results.
Thanks for your help dude!!!
Adam
Re: Ten π assembly - Bracing and foam filler [message #34754 is a reply to message #34752] Tue, 15 January 2002 04:42 Go to previous messageGo to next message
I will do that, thanks... A friend of my dad uses some hardening foam stuff to build racing boats, I might try to get some off him.
Adam
Re: Ten π assembly - Bracing and foam filler [message #34766 is a reply to message #34749] Tue, 15 January 2002 23:21 Go to previous messageGo to next message
tom clark is currently offline  tom clark
Hello Wayne-
What is the benefit of going with the horn?
Thanks again for sharing your knowledge.
Ten π horn participation in system response [message #34767 is a reply to message #34766] Wed, 16 January 2002 00:24 Go to previous message
Horn loading improves efficiency, increases maximum output and reduces distortion.
Previous Topic: Impedance question for the smart guys
Next Topic: Rear ports for PA speakers?
Current Time: Sun Oct 25 04:47:30 CDT 2026
