Home » Sponsored » Pi Speakers » 4 pi's
4 pi's [message #34755] Tue, 15 January 2002 10:23 Go to next message
spkrman57
Wayne, I want to build a pair of 4 pi's using JBL 2226J's (16 ohm) and JBL 2418's (8 ohm) on JBL 2373 horn lens. I know the quasi-first-order crossover I need (1.6khz). I need the plans for the cabinets. I will be able to build the cabinets while I am breaking in the 2226's (suspension stiff as hell - I have JBL 2205's that are broken in as reference). One other question I have: Is it necessary to have the horn/driver inside the cabinet, or can it be placed on top of the cabinet???? Please send me plans if you would. Thanks in advance. Regards, Ron
Re: 4 pi's [message #34756 is a reply to message #34755] Tue, 15 January 2002 11:07 Go to previous messageGo to next message
Check your mail. The only thing that's different with the 2226J's is that L2 should be 1.4mH. All other crossover components are the same. You can put the tweeters on top if you want. Lots of people do that, especially those with wood horn tweeters.
By the way, I love those 2205's. They were the part that preceded 2226's in all my designs using 15 inch woofers from JBL. Used a ton of 'em in the eighties.
Re: 4 pi's [message #34768 is a reply to message #34756] Wed, 16 January 2002 04:12 Go to previous messageGo to next message
spkrman57
Wayne, Thanks for the plans. I can't figure the depth of the port though. Regards, Ron
Re: 4 pi's [message #34773 is a reply to message #34768] Wed, 16 January 2002 14:49 Go to previous messageGo to next message
The port is 10 inches long, 6 inches tall and 3.5 inches wide, all inside dimensions.
Re: 4 pi's [message #34790 is a reply to message #34773] Thu, 17 January 2002 10:54 Go to previous message
spkrman57
Wayne,
Thanks for the info. At work where I have computer/internet. I can't find a print pgm to work on some of the e-mail/attachments I receive. I work for the Govt. so I have to sneak in my time carefully and do what I can.
That port area sounds fairly large for such a small cabinet.
Previous Topic: exteme bass drowning out treble and midrange
Next Topic: More Midwest Audio gathering stuff!
Current Time: Wed Oct 14 21:51:08 CDT 2026
