Home » Sponsored » Pi Speakers » initial thoughts on my ten pi's...
Re: Ten π assembly - Bracing and foam filler [message #34740 is a reply to message #34737] Mon, 14 January 2002 15:32 Go to previous messageGo to previous message
You sent me a text document called "PIALIGN" which includes a large essay on pi speakers and plans for the normal bass reflex boxes and corner horns using measurements based on x,y and z ratios. You've said the ten pi was essentially a scoop flair added to the normal reflex box so that's what I did, scaling the units to fit as needed. I included wood thickness and driver volume offsets when calculating box size. That's what confused me because it didn't match what I expected it was much smaller. That's why I fudged it some.
Adam
Previous Topic: Impedance question for the smart guys
Next Topic: Rear ports for PA speakers?
Current Time: Sat Nov 07 05:43:06 CST 2026
