Home » Sponsored » Pi Speakers » T/S parameters for eminence 18"
T/S parameters for eminence 18" [message #34703] Sat, 12 January 2002 09:56 Go to next message
dtkky is currently offline  dtkky
Hi,
This may be a long shot, but does anybody have the T/S parameters for an old model Eminence 18" driver (model no. C18B109 )?
Thanks
David Tan
Eminence specifications prior to 1999 [message #34706 is a reply to message #34703] Sat, 12 January 2002 12:51 Go to previous message
According to Eminence, all motors manufactured prior to 1999 were "made to order" and specifications were dictated by the purchasing distributor. So, with the exception of large vendors, there will likely not be a "standard" Eminence product before that time. You might have been able to find a standard Eminence offering from a particular vendor (as I did), but you could not have found an Eminence offering that was standard between vendors.
This is described in a letter from Chris Rose
Previous Topic: 3677s
Next Topic: when it rane's it pours
Current Time: Sun Nov 22 23:17:15 CST 2026
