Home » Sponsored » Pi Speakers » JBL tent sale - JBL 2226J crossover values
Re: JBL 2226 crossover values [message #34684 is a reply to message #34683] Thu, 10 January 2002 12:24 Go to previous messageGo to previous message
If you use a single 0.7mH coil, you will be flat to 1.6kHz. That's what the crossover in the Professional Series cabinets uses. This is a pseudo first-order configuration, which doesn't provide the sort of curve you'd expect: It removes about 2dB from 1kHz up - and attenuation is fairly constant above that point. So if you choose to crossover lower, you'll need a different crossover, and you'll probably want to use a Zobel. The single coil pseudo first-order solution does not require a Zobel.
Previous Topic: Wayne... C5
Next Topic: cornerhorns, more questions
Current Time: Mon Nov 23 01:06:33 CST 2026
