Home » Sponsored » Pi Speakers » beta-15 & 4Pi
beta-15 & 4Pi [message #34662] Tue, 08 January 2002 07:42 Go to next message
Otor is currently offline  Otor
Hi there,
I have not started to build 2Pi yet, because i am hesitating to
start may be with a dessign offering more bass.
I can't find any comments/recommendation of Beta-15 speaker in 4Pi.
Is there some reason I ignore ?
After last change of Eminence parameters, it seems that Beta-15
is quiet good replacement for oldest Aplha-15: require the similar box
dimensions and offer the similar bass response
(Beta-15 in 7cu ft has -3dB at 44Hz, Alpha-15 -oldestt- had
-3dB at 42Hz in 8 cu ft).
This is nearest than new Alpha-15 which require 11.5 cu ft.
Is there some sonic penalty for Beta-15 ?
Thanks in advance,
O'Tor.
Re: beta-15 & 4Pi [message #34665 is a reply to message #34662] Tue, 08 January 2002 13:25 Go to previous messageGo to next message
The Studio Series two π loudspeaker sounds good and makes pretty good bass for a small speaker, but the Theater Series four π is very popular and definitely does better in this regard.
Re: beta-15 & 4Pi [message #34672 is a reply to message #34665] Wed, 09 January 2002 09:38 Go to previous messageGo to next message
Hi Wayne,
Thanks for your response. I would also like to ask you if the
midrange quality of Alpha-based one and two Pi is the same.
I.e. the only change for the passing from one Pi to two Pi is
the benefit of deeper bass ?
I am asking this because in the hifi-line, there is often some
midrange degradation for the largest cones, especially when they
are used with no low-pass crossover (often a huge peaks and
irregularities in the 3-5kHz region, and often not shown on the
driver SPL plot but still audible).
TIA,
O'Tor
Re: beta-15 & 4Pi [message #34677 is a reply to message #34672] Wed, 09 January 2002 12:29 Go to previous messageGo to next message
Both the one π and two π loudspeakers have very smooth sounding midrange, in my opinion.
Thanks Wayne, I start with alpha 2Pi then! <nt> [message #34682 is a reply to message #34677] Wed, 09 January 2002 23:56 Go to previous message
nt
Previous Topic: stacking 4 pi's
Next Topic: Wayne... C5
Current Time: Sun Nov 22 23:46:26 CST 2026
