Home » Sponsored » Pi Speakers » Possible use of Lambda woofer in Pi enclosure.
Both Solen and Daytons sound great [message #34658 is a reply to message #34634] Mon, 07 January 2002 21:44 Go to previous messageGo to previous message
Mike Bates is currently offline  Mike Bates
in the 15- 25 mfd range. I like them better than some expensive paper in oils I tried. The Solens are tighter tolerance so probably worth the extra couple of bucks. You can bypass them with an expensive .33 or something if you want. It might sound better. Cheap resistors seem to muck up the sound most IME. The Mills 12 watters are really good if your using little amps. Around $3.00 a piece at Parts Express.
Mike Bates
Previous Topic: Pi Four JBL Pro Plans
Next Topic: Attention: If you own JBL 3677S click here
Current Time: Mon Oct 05 16:29:12 CDT 2026
