Home » Sponsored » Pi Speakers » theater 4/7 cornerhorn combo mombo
theater 4/7 cornerhorn combo mombo [message #34649] Sat, 05 January 2002 12:07 Go to previous message
rewfew is currently offline  rewfew
Say Wayne:
I'm assuming the cabinet volume for the theater 4 bass reflex is the same as with the 7 pi corner horn using the delta 15 eminence driver. So what if one had the HF driver and horn housed separately, unattached atop the the bass cab. If you want the theater 7 you'd use removable panels that can be screwed or bolted above and below the speaker to form the doghouse reflector of the corner horn or you could undo the panels for the theater 4 and flip er round. But how much of the crossover parts share compatability? If it's just a matter of a few resistors or caps for the compensation network then a flip of a switch could finish the change over.
Previous Topic: Inductor Value for Theater 4 Pi
Next Topic: Questions about wiring Theater 4 Pi's and Paramour tube amps.
Current Time: Tue Nov 03 16:14:55 CST 2026
