Home » Sponsored » Pi Speakers » Question for Till E.
Question for Till E. [message #34643] Fri, 04 January 2002 05:10 Go to previous message
Till,
You earlier mentioned that you did not have the RC network on the woofers of your Theater 4's. You also said that the Paramours were sounding great with the Pi's. On another post you said there was too much bass with the RC network not installed. I was just curious what your latest feeling is? Have you installed the RC network(Zobel) yet and if so what is the sonic result?
My Paramours arrived this week and construction begins this weekend. The Theater 4's are cut and almost ready for assembly. I'm building the Cross-over externally so that is the last to work on and I may try the set up with out the Zobel to cut down on all the reactive clutter on the signal path but I suspect that the zobel is probably going to go in!
Garland
Previous Topic: Tweaking Eminence Delta 15
Next Topic: Inductor Value for Theater 4 Pi
Current Time: Fri Nov 20 14:25:42 CST 2026
