Home » Sponsored » Pi Speakers » PiAlign RS1354?
Re: PiAlign RS1354? [message #34636 is a reply to message #34626] Thu, 03 January 2002 07:44 Go to previous messageGo to previous message
Otor is currently offline  Otor
Hi Craig,
I calculated Pi Align for RS-1354 some time ago, but not built them.
Where I was confused was a really small port dimensions.
In the Pi align, there is another factor to be considered, which
is the ratio Qe = Lp^2/Ap. For RS-1354 in 0.234 cu ft Pi aligned
box tuned to 41.6 Hz, this ratio is 2.206. The only possible port dimension I found is Dp=0.414" and Lp=0.545" - not a huge port, it
risks to produce some noise, IMHO.
I do not understand exactly how important is to keep this ratio close to calculated Qe value. What's more important: use such a small
port or make the port bigger and then keep right values for Qe or rather for Fre?
O'tor
Previous Topic: Are there any Plans available
Next Topic: Tweaking Eminence Delta 15
Current Time: Fri Nov 20 14:26:28 CST 2026
