Home » Sponsored » Pi Speakers » Plye drivers
Plye drivers [message #34580] Sat, 29 December 2001 09:13 Go to next message
I have a couple of old 12 inch Pyle MH1229 speakers lying around. The specs are:
voice coil= 1.5 in
sesitivity= 97 dB
fs= 59 Hz
Vas= 3.2 cu ft
Qts= .55
power= 95 watts
frequency responce= 65-6.5 kHz
Are these speakers worth using in a full range system with a compression horn and crossover? And what type of enclosure would work best?
Thanks in advance.
Dave
Re: Plye drivers [message #34585 is a reply to message #34580] Sat, 29 December 2001 11:27 Go to previous messageGo to next message
Naw, those are pretty crap drivers. Probably not worth the purchasing of quality compression drivers and crossover parts. The T/S specs are likely all wrong anyway.
Adam
Re: Pyle drivers [message #34586 is a reply to message #34580] Sat, 29 December 2001 11:33 Go to previous message
From the specs, that speaker works best in a two to eight cubic foot box, port tuned to 40Hz. PiAlign suggests 2 cubic feet, tuned to 40Hz with a 2.2" long, 2.5" diameter port. Deepest flat response is obtained with an 8 cubic foot box, tuned to the same frequency.
Previous Topic: More on the cheap 200 dollar PA speakers I want to build
Next Topic: 2 1/2 watt Tube Amp Runs Amok!!!
Current Time: Sat Nov 14 13:33:02 CST 2026
