Home » Sponsored » Pi Speakers » Crossover information
Crossover information [message #34573] Fri, 28 December 2001 22:20
You can scale components L1, L2, C2, C3 and C4, and the R3/C5 damper is easy enough to calculate for. But the compensation network formed with R1, R2 and C1 is not so easy because we are setting a very precise Q value simultaneously with the bypass frequency. You'll need to find these values using Spice. This is the curve you're looking for:
Previous Topic: Is it possible to build the 4 Pi's as 16 ohm speakers?
Next Topic: More on the cheap 200 dollar PA speakers I want to build
Current Time: Mon Oct 26 08:43:34 CDT 2026
