Home » Sponsored » Pi Speakers » More on the cheap 200 dollar PA speakers I want to build
More on the cheap 200 dollar PA speakers I want to build [message #34570] Fri, 28 December 2001 21:17 Go to next message
Jerry Parker is currently offline  Jerry Parker
My friend is pretty set on spending 200 bux on the pair. I doubt he will go any higher, and i cant say that i blame him, I dont have that much money either after dropping $250 on my blueprint 1803 18" driver.
So I guess we will most likely have to use piezos. I dont really like the sound of them, but hopefully we can find a nice one for the price.
As for the woofer, a 10" or 12" eminence alpha series would fit the bill perfectly.
What do you guys think? Are there any compression drivers out there that cost 30 or less? That are of decent quality? I figure about 80 for two woofers, 60 for two HF drivers will leave 60 dollars for xover parts and enclosures. Can it be done? Thanks.
Re: What about these HF drivers? [message #34571 is a reply to message #34570] Fri, 28 December 2001 21:57 Go to previous messageGo to next message
What about these compression horn drivers, would they work? http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Product_ID=16172&CATID=49
Re: More on the cheap 200 dollar PA speakers I want to build [message #34572 is a reply to message #34570] Fri, 28 December 2001 22:02 Go to previous messageGo to next message
SirAdam is currently offline  SirAdam
Here... An Alpha 10" coupled with a supertweeter. Both Eminence equipment, no piezos. Cross the two over at 4 or 5 kHz, second order on the tweeter, first on the woofer, or even no crossover on the woofer (I'm not really into that though, since I don't know the exact FR of the woofer). Also have to attenuate the tweet by 8-10 db. With the sale, the combined price should be around 130 dollars plus some shipping. It should leave you *just* enough to build the crossovers and enclosures without going much over 200.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Product_ID=7637&CATID=49
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Product_ID=7579&CATID=49
Adam
Re: What about these HF drivers? [message #34575 is a reply to message #34571] Fri, 28 December 2001 23:04 Go to previous message
If you build with any of those drivers, let us know what you think.
Previous Topic: Crossover information
Next Topic: Plye drivers
Current Time: Mon Oct 26 08:46:14 CDT 2026
