Sponsored
Is it possible to build the 4 Pi's as 16 ohm speakers?
Re: Is it possible to build the 4 Pi's as 16 ohm speakers?
message #34568
is a reply to
message #34559
Fri, 28 December 2001 20:20
Adam
May 2009
If you're doubling impedance, you should use coils twice as large and caps half as large to get the same xover. Also, the resistors should be twice as large as well. As for the impedance compensations, might be a bit more tricky...
Adam
Message index
By:
Charlie G
on Thu, 27 December 2001 19:02
By:
on Thu, 27 December 2001 21:05
By:
Adam
on Fri, 28 December 2001 20:20
Wayne, double loading
Crossover information
Mon Oct 26 12:42:25 CDT 2026
