Home » Sponsored » Pi Speakers » Wooden Horn Update
Re: Wooden Horn Update [message #34526 is a reply to message #34524] Sun, 23 December 2001 16:47 Go to previous messageGo to previous message
The more I look at the Yuichi design, the more simple it becomes. A bowl turning that's not scooped out; cut exactly in half; mortised with a horizontal boring rig fitted with an end mill and the various triangles and trapezoids glued in place.And of course a turning for the thingy that attaches the compression doohickey.
For whatever reason Yuichi chose a lamination for his bowl, solid stock could also be used. That thickness should be dimensionally stable in almost any hardwood. I like the acoustic properties of mahogany and maple in that order. Mahogany is easier to acquire in 16/4 and more stable in central-heating-land.
C'mon Garland, you can do it!
Previous Topic: Crossover help: more confused than ever!
Next Topic: Horn Lens for Theater 4 Pi - Eminence H295 ?
Current Time: Tue Nov 24 21:09:51 CST 2026
