Home » Sponsored » Pi Speakers » Wayne, creating large corner horn for non-corner use...
Wayne, creating large corner horn for non-corner use... [message #34446] Sun, 16 December 2001 15:34 Go to next message
Hey, I was wondering what your thoughts are on building a 7 pi corner horn, and rather then placing it in the corner of a room, use plywood to build a giant horn mouth like the corner of a room so it can be used in places other then in a corner.
It would prolly be pretty big, with the horn edge shooting out like 4' with a giant mouth, very difficult to move, very heavy... Do you think it would be worth it? Would it have the same effect as a standard corner placement???
Thanks
Adam
That's a freestanding horn, like the ten π folded horn [message #34447 is a reply to message #34446] Sun, 16 December 2001 18:04 Go to previous message
You could make "wings" for a seven π, but I think it would be awkward to setup and move braced panels. Probably better to use a ten π folded basshorn.
Previous Topic: Extended High End on Compression Drivers
Next Topic: JBL tent sale update
Current Time: Sat Oct 17 14:11:54 CDT 2026
