Home » Sponsored » Pi Speakers » pushin' Eminence 1" to 1.2KHz - how well does it work?
pushin' Eminence 1" to 1.2KHz - how well does it work? [message #34413] Sat, 15 December 2001 11:29 Go to next message
freddyi is currently offline  freddyi
Hi Wayne and group -
right now have a long-throw (9.5mm) Eminence built 4 ohm car woof in a 12" Karlson - - almost "reaches" a CD-8 Eminence driver on 811 - running ~ textbook 1.8Khz network its lacking some midrange "life" - believe part of the problem besides limited woofer HF extention is due to baffle tilt of Karlson which may demand a driver with rising on-axis response (btw - the little Karlson woofer kicks pretty well)
anyhow - have any of you run your Eminence 1" drivers in 1.2Khz xover regions and if so how were sound and dynamics? - I've tried 1.2K 3rd order hipass and it seemed relatively unstrained - didn't try it at intense levels - am tempted to run 4th order passive hi-pass.
Best wishes!
Freddy
MD2001 - Good down to 1Khz; PSD2002 - Slightly higher [message #34414 is a reply to message #34413] Sat, 15 December 2001 12:01 Go to previous messageGo to next message
I think you'll be OK with 1.2kHz crossover point, certainly if over 2nd or 3rd order. The MD2001 is good to 1kHz, the PSD2002 a little higher. I cross mine over at 1.6kHz third-order but 1.2kHz is probably OK if the horn loads there and the slope is high enough.
Re: MD2001 - Good down to 1Khz; PSD2002 - Slightly higher [message #34415 is a reply to message #34414] Sat, 15 December 2001 12:56 Go to previous messageGo to next message
I find it weird that Eminence only advertises the frequency response of the 2002 as down to 1.5 kHz, yet the power rating is at 1 kHz. I am in agreeance with Wayne, I think you could run it down to 1.2 without a problem, you'll lose some power handling, though.... If you can keep the volume down a bit it should be fine.
Cool rendered image! [message #34416 is a reply to message #34415] Sat, 15 December 2001 13:29 Go to previous messageGo to next message
Very cool rendering? What did you use to do that?
I've become pretty good with Imagine, Pv3D and Pov-Ray. I love that stuff!
Re: MD2001 - Good down to 1Khz; PSD2002 - Altec horns [message #34417 is a reply to message #34414] Sat, 15 December 2001 13:42 Go to previous messageGo to next message
Hi Wayne and group!
thanks for the reply (wow - great image by Adam!!)
-looked at my old graphs of the Eminence CD-8 without network on Altec horns - 811 has a LF corner just ~ 500Hz and 511 somewhat below 400Hz ~1/2 octave so these old horns should provide some decent loading. btw - a PV CH-2 looked real smooth - not sure about the compensation needed - surprisingly, it measured very extended in HF - sounded kinda laid-back - is CH-2 considered CD?
Very Best!
Freddy
Peavey horns [message #34419 is a reply to message #34417] Sat, 15 December 2001 14:08 Go to previous messageGo to next message
I've used Peavey CH-3 horns for quite a while. At first, I was concerned about their two-piece design. But after testing and trying them out for a while, I realized there was no consequence. The seam is acoustically small and they measure and sound nice.
Re: Peavey horns - maybe mine are CH-3? [message #34420 is a reply to message #34419] Sat, 15 December 2001 14:23 Go to previous messageGo to next message
Hi again Wayne!
my Peavey have a 10" by 19" flange, are 2-piece with depth to throat (which has a round-square inital transition) is ~11.625" - are those CH3?
take good care!
Freddy
Nope. Yours are bigger. [message #34421 is a reply to message #34420] Sat, 15 December 2001 14:32 Go to previous message
The CH-3 has a 5" x 14" mouth.
Previous Topic: Crossover Distortion
Next Topic: Compressed fiber carpet pad for cabinet damping?
Current Time: Sun Nov 22 20:41:21 CST 2026
