Home » Sponsored » Pi Speakers » PA speaker w/Eminence drivers
PA speaker w/Eminence drivers [message #34331] Wed, 05 December 2001 18:52 Go to next message
RyanH is currently offline  RyanH
Hi, I'm working on building a pair of 2-way PA speakers for my mom for mobile karaoke use. My dad might also use them for local band performances. Basically, they need to be fairly cost effective and full range, since there will be no sub. I want something with some impact too (I hope I'm not asking too much). I was thinking a 12" 2 way with a 1" compression driver would work well, but I have no experience with pro speakers. Will a single 12" in a ported box provide enough impact? I would like to keep it under 3 cu ft if possible. If anyone has seen the prices on Eminence at www.partsexpress.com, you can see why I'm asking about using Eminence drivers. I was thinking a Delta 12LF with a PSD2002 or the Selenium 1" compression driver thats $50 (can't remember the name now). Thanks in advance for any suggestions and please feel free to rip apart my plan if it won't work!
--Ryan
Re: PA speaker w/Eminence drivers [message #34337 is a reply to message #34331] Thu, 06 December 2001 12:45 Go to previous messageGo to next message
The Theater Series three π speaker uses an Eminence Delta 12LF and a PSD2002 on an H290 horn flare. It's a great sounding speaker, and it sounds good without a subwoofer. Check your mail because I've sent you the plans for it.
Another option you might consider is the Stage Series four π speaker. It uses an Omega 15 and a PSD2002 on an H290 horn flare. It's slightly more efficient and will handle more power, so it's more rugged and produces higher SPL.
Re: PA speaker w/Eminence drivers [message #34340 is a reply to message #34337] Thu, 06 December 2001 14:17 Go to previous messageGo to next message
Wayne,
Thank you! This is great! It looks like this crossover had a lot of work put into it and I'm sure it sounds great.
--Ryan
At this very moment...... [message #34342 is a reply to message #34337] Thu, 06 December 2001 16:33 Go to previous message
Andy G is currently offline  Andy G
.... I am playing with the beta 12 (reflex) + beta 12LT (sealed) + cts ksn1142/1151.
Its probably a bit bigger than you want though !!
Previous Topic: Re: Compression driver magnet shielding
Next Topic: Speaker Question
Current Time: Thu Nov 19 10:48:26 CST 2026
