Home » Sponsored » Pi Speakers » PA speaker w/Eminence drivers
Re: PA speaker w/Eminence drivers [message #34337 is a reply to message #34331] Thu, 06 December 2001 12:45 Go to previous messageGo to previous message
The Theater Series three π speaker uses an Eminence Delta 12LF and a PSD2002 on an H290 horn flare. It's a great sounding speaker, and it sounds good without a subwoofer. Check your mail because I've sent you the plans for it.
Another option you might consider is the Stage Series four π speaker. It uses an Omega 15 and a PSD2002 on an H290 horn flare. It's slightly more efficient and will handle more power, so it's more rugged and produces higher SPL.
Previous Topic: Re: Compression driver magnet shielding
Next Topic: Speaker Question
Current Time: Thu Nov 19 11:37:58 CST 2026
