Home » Sponsored » Pi Speakers » Four PI Thermionic & 1K6a012dB
Four PI Thermionic & 1K6a012dB [message #34309] Sun, 02 December 2001 14:51 Go to next message
John B. is currently offline  John B.
I have the four pi thermionic plans, and I've already started assembling the boxes - parts are and will be on order. I fully intend to build the four pi's, but would like my knowledge as complete as possible.To this end, I do, however, have a question.
Using the spice tools and circuit models you provide; and other number crunching and plotting tools:
No matter how I analyze and model the system I seem to predict a 3 or so octave wide notch in the response centered at about 2000Hz. Am I correct? The notch is apparently crossover generated, and I can't find any component of the system which compensates, or for which it compensates.
I imagine this is probably a more complex issue than I am assuming - what with phase cancellations and so forth. But it bothers me :) and inquiring minds want to know.
Thanks.
Compensation for compression horns [message #34310 is a reply to message #34309] Sun, 02 December 2001 19:23 Go to previous messageGo to next message
The crossover is asymmetrical, so the electrical crossover points don't line up. There is also top-octave compensation in the tweeter circuit, which attenuates the lower region much more than HF. This is all done on purpose to make the overall response curve as flat as possible. The crossover was carefully designed to provide good response, both on axis and off, with uniformly collapsing directivity that is matched at crossover and constant above that.
Wayne, I have a question... [message #34311 is a reply to message #34310] Sun, 02 December 2001 19:58 Go to previous messageGo to next message
What crossover point do you think is best for the PSD2002? I choose a 1.5 kHz xover point on my design.
Thanks!!
Adam
Eminence PSD2002 crossover frequency [message #34314 is a reply to message #34311] Mon, 03 December 2001 00:32 Go to previous messageGo to next message
That's perfect. I like to crossover between 1.2kHz and 1.6kHz.
Re: Eminence PSD2002 crossover frequency [message #34318 is a reply to message #34314] Mon, 03 December 2001 11:27 Go to previous message
Alright thanks Wayne.
Adam
Previous Topic: Getting to the bottom end of 2245's
Next Topic: surplus eminence & jbl
Current Time: Tue Jul 16 08:38:57 CDT 2024
