Home » Sponsored » Pi Speakers » Shape of box
Shape of box [message #34303] Sun, 02 December 2001 07:35 Go to next message
Frode is currently offline  Frode
Hi Wayne!
PiAlign recommends values for height, width and depth. If I change these but NOT the net volume, will this affect the speaker in any way?
Frode
Re: Shape of box [message #34304 is a reply to message #34303] Sun, 02 December 2001 09:02 Go to previous message
You can generally change the shape of the box as long as you don't make it so standing waves setup inside the box in the bass or midbasss range. The damping material inside the box attenuates midrange and higher standing waves, but it is acoustically transparent at low frequencies. Avoid tall thin "tower" enclosures unless you are trying to design a transmission line. If you do build a tall thin box and intend to tune it with Helmholtz resonance instead of 1/4 wave modes, then you'll have to carefully position the woofer and port so they aren't energized by standing wave nodes.
Previous Topic: Port detail for pro 7 pi's
Next Topic: closed vs. vented sub-woofer box
Current Time: Mon Nov 09 10:39:57 CST 2026
