Home » Sponsored » Pi Speakers » closed vs. vented sub-woofer box
closed vs. vented sub-woofer box [message #34296] Sat, 01 December 2001 15:10 Go to next message
Ordered a 10" woofer from P.E. that was supposedly made for and refused by Klipsch. Great big shielded aluminum thing, $95. Also the 120 watt plate amp for an astounding $79!
It seems as though most of the P.E. verbiage concerns closed boxes, as well as some DIY sites. It seems the closed boxplots are a little deeper than vented. Is bass QUALITY better with vented?
This particular woof is:
FS 32.8
Vas 3.24
QMS 7.95
QES .21
QTS .20
XMAX .18"
Boxplot likes a 3.5 cu.ft. vented, way smaller closed.
So what's better?
Re: closed vs. vented sub-woofer box [message #34298 is a reply to message #34296] Sat, 01 December 2001 18:48 Go to previous messageGo to next message
Most people use a rule of thumb that essentially says high Qts, low Fts speakers go in sealed boxes and low Qts, high Fts speakers go in ported boxes. I prefer to use bass reflex, and the reasons why are discussed in the threads called "Acoustic Suspension vs. Bass Reflex" and "Pi Alignments compared with B4, C4 and QB3."
Response curves of closed vs. vented systems [message #34305 is a reply to message #34298] Sun, 02 December 2001 10:32 Go to previous message
Several graphs are shown below that describe various common tuning methods along with a couple examples of mal-aligned systems. I was asked to do this a few days ago, and with Till's most recent post, it seemed an opportune time to illustrate the response that can be expected from various systems.
Each of these graphs were prepared using a woofer motor having the following characteristics:
Fts = 30 Hz
Vas = 5 cubic feet
Qms = 5.0
Qes = 0.4
Qts = 0.37
Re = 6.0 ohms
Le = 1.0 mH
Xmax = 0.22 inches
Efficiency - 90dB@1W/1M
Note that I use the term "optimal" in a way that can be interpreted to mean "critically damped." In other words, when I describe an "optimally tuned cabinet" or one having "optimal size", many would refer to this as being critically damped. There is merit in building systems that are not critically damped for various reasons, and one should not misinterpret the term "not optimal" as excessively derogatory. However, "critically damped" motor cabinets provide the best performance, so the term "optimal" is accurate.
Optimal Sealed Alignment
This is the absolute best frequency response that can be obtained using this woofer in a sealed cabinet. Notice that the -3dB point is approximately 55Hz.
Optimal Ported Alignment
This is the absolute best frequency response that can be obtained using this woofer in a ported cabinet. This is the alignment that can be expected from PiAlign'ed cabinets for woofers having Qts between about 0.3 and 0.5. This is also known as a fourth order Butterworth alignment, or B4 for short. Notice that the -3dB point is approximately 35Hz.
Overdamped Sealed Alignment
The response curve shown above results from placing a woofer in an oversized sealed box. As the cabinet is made larger, the -3dB cutoff point does not drop, and in fact, begins to get marginally higher. But the total energy available "under the curve" grows because there is more usable response at very low frequencies. The trouble is that this is also where the woofer is generating the majority of its distortion. Personally, I would prefer to extend the -3dB point down to the resonant frequency of the woofer, and then allow the entire system to unload so that high distortion generating frequencies below woofer resonance are attenuated. Nevertheless, this is a common alignment with some builders because relatively flat and deep bass response is assured.
Overdamped Ported Alignment
Here we see response from placing a woofer in a ported cabinet that is a little larger than optimal and tuned a little lower than optimal. It is typical of PiAlign'ed cabinets for woofers having Qts below 0.3. The response curve is similar to that shown for an overdamped sealed cabinet, and if the system is tuned significantly below woofer resonance, then performance is very much the same. As was the case with overdamped sealed cabinets, care must be taken to ensure that system distortion doesn't rise if the -10dB point is at a low frequency where woofer distortion is high. But typically, because of the quick rolloff slope of ported systems, this is not as much a problem.
Third order Quasi-Butterworth (QB3) alignments are commonly generated for systems having woofers with Qts less than 0.3, and these have response curves that look very much like the C4 systems shown below. However, PiAligned cabinets are more likely to be slightly overdamped as shown above, than they are to have QB3 characteristics. PiAlignments tend to "favor" overdamped systems for woofers like these.
Underdamped Sealed Alignment
This is the response curve resulting from placing a woofer in a sealed cabinet that is a little too small. When a woofer is placed in a sealed box, the only thing that can result in an underdamped system is box size being too small, and it will always shift the resonant frequency and -3dB point up.
Underdamped Ported Alignment, tuned high
This is the result of placing a woofer in a ported cabinet that is tuned slightly higher than optimal frequency. Unlike a sealed cabinet, two things can cause a ported cabinet to be underdamped - non-optimal tuning frequency or non-optimal box size. This particular alignment is typical of PiAlign'ed cabinet for woofers having Qts greater than 0.5 and relatively small Vas.
Underdamped Ported Alignment, tuned low
The response curve shown above is from placing a woofer in a ported cabinet that is slightly larger than optimal. This is called a Fourth order Cheyshev (C4) alignment and it is typical of PiAlign'ed cabinet for woofers having Qts greater than 0.5 and relatively large Vas.
EBS Stepped Response from ported cabinet with specific peaking
This is an interesting response curve, formed when a ported cabinet is larger than optimal and also tuned lower than optimal - both by a specific amount. It is a useful alignment for extanding bass response.
Grossly Underdamped Sealed Alignment
When a woofer is placed in a sealed chamber that is extremely small, the system becomes massively underdamped. All of the alignments above can be considered to be viable system solutions, but this one is not. It is merely shown for illustrative purpose.
Grossly Underdamped Ported Alignment
When a woofer is placed in a ported cabinet that is tuned too high or too low or if the cabinet is too large or too small, the system can become massively underdamped. Notice that the example of a grossly underdamped sealed cabinet can be caused by only one thing - the chamber being too small - but a ported cabinet can be made underdamped by excessively "going any direction" with its tuning. As with the grossly underdamped sealed cabinet, this "alignment" is non-viable and is merely shown for illustrative purpose.
Previous Topic: Shape of box
Next Topic: PiAlign questions: ideal vs enclosure Q (and Kappa15LF looks sweet!)
Current Time: Thu Nov 05 20:43:45 CST 2026
