Home » Sponsored » Pi Speakers » Crossover placement question
Crossover placement question [message #34082] Wed, 24 October 2001 17:18 Go to next message
Time to wire up the Theatre 4's. Shortest signal path would put the crossover on the front baffle between the tweet and woof. Using a sorbothane pad under the board for dampening. Any reason not to put it there? Any better location?
One more thing. The fancy binding posts I got came with solder lug/washers, kinda what you see with some female RCA's. Why the heck would you want to ground the speaker wires? Or are they intended for the signal wires? They're Daytons from Parts Express.
Re: Crossover placement question [message #34083 is a reply to message #34082] Wed, 24 October 2001 18:23 Go to previous messageGo to next message
Crossover placement is up to you. Main thing is seviceability. Since you'll probably be assembling these on their backs, the back panel makes sense. It's between the drivers too, as you said.
Re: Crossover placement question [message #34084 is a reply to message #34082] Wed, 24 October 2001 18:52 Go to previous messageGo to next message
hi till, place the x-over outboard. buy some cardas or wbt binding posts and wire the woofer through them. leave the x-over outside ( mine are on the floor behind the cabinets) this way you never have to open the cabinets and the x-over is available for unlimited tweaking. us freaks always need something to do, even when we are happy with the sound.
cheers,
george
Re: Crossover placement question [message #34085 is a reply to message #34082] Wed, 24 October 2001 19:08 Go to previous message
Thanks, guys. I'm going inboard, the tweeking is done: Auricaps, Mills wirewounds, Jena wire. And there's that great big hole to get back inside down the road. This time tomorrow I should be disturbing the peace. They look awesome, can't wait to hear them.
Let you know how they sound.
Sweaty roadies and 200 volts, Yikes!
Previous Topic: JBL 2245's still available?
Next Topic: Bracing: expansion foam
Current Time: Tue Oct 20 21:38:48 CDT 2026
