Home » Sponsored » Pi Speakers » min size of port
min size of port [message #34035] Wed, 10 October 2001 03:14 Go to next message
Observator is currently offline  Observator
Hi Wayne,
I would ask you about port dimensions of Pi Align
model: back to my PiAfterburner Eminence Beta12LTA:
Fs=45,Qts=0.51,Vas=2,4548cuft,
PiAlign give me
Ve 2,454828132 cuft
Fre 33,08823529 Hz
Qe 1,388888889 -
to achieve exact Fre and Qe for this box, the optimal port
Diameter is 2.408" and Length is 2.515" (calculated in excel).
Use of a larger port cause rise of the Qe/Fre.
Using this port dimensions in other software (WinISD for example)
show me the red numbers for this port: 0,41 mach in Vent, that
means noise or Doppler distortion risk.
Have I to consider this risk or is it something different
for the Pi align approach ?
Thanks in advance,
O'Tor
Re: min size of port [message #34039 is a reply to message #34035] Wed, 10 October 2001 09:33 Go to previous message
Depends on the displacement. The Beta LT has peak displacement volume of 42cc, which is only 2.5 cubic inches. That's not very much to push through a 2" diameter port, so airspeed won't get anywhere near 40% mach, which is 300mph and 480kph. By the way, maximum airspeed is at fb, and falls off above that.
Previous Topic: Pi Web site
Next Topic: dynamat or plain old fiberglass pink?
Current Time: Wed Nov 04 04:53:56 CST 2026
