Wayne Parham Messages: 18738 Registered: January 2001
The response curve is flat to 45Hz, down -3dB at 38Hz and -10dB at 30Hz. Its thermal limits and excursion limits are almost the same, giving maximum output of about 110dB at 1 meter. Within the passband, excursion is the limit between 50Hz and 80Hz and heat is the limit above and below that point. Obviously, the excursion limit is quite low below 35Hz, so high pass at that point.
