Home » Sponsored » Pi Speakers » Pi Aligned Afterburner & Port Calculation
Re: Pi Aligned Afterburner & Port Calculation [message #33970 is a reply to message #33949] Sat, 29 September 2001 13:02 Go to previous messageGo to previous message
Observator is currently offline  Observator
Thank you for the response.
...but my problem persist....
> You used 2.4 as as cabinet volume but you should have used 2.4 x
> 1728 to convert it to cubic inches. You must use the same terms
> throughout - If inches in one place then inches must be used
> everywhere. You can use feet if you wish, but then the port
> dimensions must be in feet for "Lc" and sq. feet for "Ap".
I suppose I am wrong but I cannot find where :-(
Question is : what is eqation Fre = 1/2pi * sqrt(Ap/VeLc)
calculating?
Using your values and formules from Pi white paper,
Ve = 2.45 cu ft = 4242 cu in then
Dp = 2.5" => Ap = 4.9 sq in
Lp = 2.75" => Lc = 4.872 in
Fre = 1/6.28 * sqrt (4.9/(4242*4.872) )= 0.00245 Hz :-(((
Thanks in advance,
O'Tor
Previous Topic: Which drivers are suitable for Pi alignment?
Next Topic: Pair of JBL 2426H drivers FS.
Current Time: Thu Nov 19 20:01:41 CST 2026
