Home » Sponsored » Pi Speakers » alpha and delta
alpha and delta [message #33925] Wed, 26 September 2001 16:27 Go to next message
canjie is currently offline  canjie
please somebody thels me about box volume for alpha 10" and alpha 12"
Box sizes and tuning [message #33930 is a reply to message #33925] Wed, 26 September 2001 17:33 Go to previous messageGo to next message
The Alpha 10 works best in cabinets from 1 to 5 cubic feet tuned to 40Hz. The Alpha 12 should be used either on infinite or open baffles or in boxes larger than 4 cubic feet tuned to 25Hz.
The PiAlign recommended cabinet for the Alpha 10 is 1.4 cubic feet tuned to 40Hz using a 1.85" diameter, 2" long port. Its suggestion for the Alpha 12 cabinet is 4.7 cubic feet tuned to 25Hz using a 2.4" diameter, 1.2" long port.
Re: Box sizes and tuning [message #33935 is a reply to message #33930] Thu, 27 September 2001 04:09 Go to previous messageGo to next message
thank you Wayne
Re: Box sizes and tuning [message #33936 is a reply to message #33935] Thu, 27 September 2001 04:28 Go to previous messageGo to next message
How can it be that Eminence alpha 12 requires volume of 138 liters for vented enclosure if Eminence kappa 15 requires less-- only 110 liters for vented enclosure ?
Re: Box sizes and tuning [message #33937 is a reply to message #33936] Thu, 27 September 2001 04:51 Go to previous messageGo to next message
The Alpha 12 has much higher Q. As a result, it needs an unusually large cabinet. As I said earlier, an infinitely large box - the infinite baffle - is a good way to run this driver. You can mount it on the wall, allowing the area between walls and the attic to be the "cabinet".
Re: Box sizes and tuning [message #33943 is a reply to message #33937] Thu, 27 September 2001 06:45 Go to previous message
thank you for your help.
Previous Topic: wayne
Next Topic: I want more bass!
Current Time: Wed Oct 21 08:47:23 CDT 2026
