Home » Sponsored » Pi Speakers » box dimensions
box dimensions [message #33901] Mon, 24 September 2001 01:47 Go to previous message
Observator is currently offline  Observator
Hi Wayne,
I have a question about your BR box dimensions. The internal
box dimension seems to be important because they could affect
the sound by a parasite resonance.
From bibliography -the most common approach is use sqrt(5)
"golden" ratios: 1/1.618 : 1 : 1.618 .
Another approach is to use - I think- 1^(x/3) ratios (where x=1,2, 4,5, 7,8,...)
to add only "agreeable harmonic" resonance.
Will another ratios will work fine too ?
Thanks in advance,
O'Tor
Previous Topic: Some build questions
Next Topic: Wayne, what do you think of this???
Current Time: Fri Nov 06 21:21:15 CST 2026
