Home » Sponsored » Pi Speakers » Eminence 12LT Pi BR Qestion
Beta 12LT in PiAlign'ed cabinet [message #33803 is a reply to message #33801] Tue, 04 September 2001 18:56 Go to previous messageGo to previous message
You asked what Pi Alignments recommend for the Eminence Beta 12LT speaker. Eminence publishes the following specifications:
Vas = 4.81 cubic feet
Fts = 45Hz
Qts = 0.51
And these correspond to PiAlign values of:
Vad = 4.81 cubic feet
Frd = 45Hz
Qd = 2.0 (1/Qts)
PiAlign recommends a bass reflex cabinet of 2.4 cubic feet tuned to 33.75Hz and having Q of 1.5. It recommends doing this using a 2.5" diameter port that's 2.75" long, which is very close to a perfect match - corresponding to Frd of 34.0Hz and Q of 1.56. Without any volume displacements, it is suggesting the cabinet be 24" x 16" x 11", but after consideration of the volume displaced by the speaker driver and the wood thickness, I'd expect your cabinet's outside dimensions to be closer to 26" x 18" x 14". And while these cabinet dimensions can be off a half inch or so, be sure the port dimensions are "right on the money." You must have inside dimensions of 2.5" diameter and 2.75" long for the design to be optimal.
Previous Topic: Port length on multiple ports
Next Topic: XO-slope for sub
Current Time: Thu Nov 19 21:34:08 CST 2026
