Home » Sponsored » Pi Speakers » Eminence 12LT Pi BR Qestion
Eminence 12LT Pi BR Qestion [message #33799] Tue, 04 September 2001 09:31 Go to next message
Observator is currently offline  Observator
Hi again,
I'm sorry but i can't find the right
dimensions of Pi-BR for Eminence 12LT...
Could you send me, please, a right
dimension of the box and of the BR ?
What's also the f3 for this dessign ?
Thanks a lot,
O'tor
Theater Series three Pi [message #33800 is a reply to message #33799] Tue, 04 September 2001 09:44 Go to previous messageGo to next message
If you are talking about the Delta 12LF, the cabinet to use is the Theater Series three Pi.
Re: Theater Series three Pi [message #33801 is a reply to message #33800] Tue, 04 September 2001 10:27 Go to previous messageGo to next message
Hi Wayne,
Unfortunately not. Its not Delta 12LF. It Is Beta 12LT used
in Thorsten Afterburner project. There was a post from you
in another forum about a Pi-align for this driver,
and i just can't find the details.
Thanks in advance,
O'Tor
Beta 12LT in PiAlign'ed cabinet [message #33803 is a reply to message #33801] Tue, 04 September 2001 18:56 Go to previous messageGo to next message
You asked what Pi Alignments recommend for the Eminence Beta 12LT speaker. Eminence publishes the following specifications:
Vas = 4.81 cubic feet
Fts = 45Hz
Qts = 0.51
And these correspond to PiAlign values of:
Vad = 4.81 cubic feet
Frd = 45Hz
Qd = 2.0 (1/Qts)
PiAlign recommends a bass reflex cabinet of 2.4 cubic feet tuned to 33.75Hz and having Q of 1.5. It recommends doing this using a 2.5" diameter port that's 2.75" long, which is very close to a perfect match - corresponding to Frd of 34.0Hz and Q of 1.56. Without any volume displacements, it is suggesting the cabinet be 24" x 16" x 11", but after consideration of the volume displaced by the speaker driver and the wood thickness, I'd expect your cabinet's outside dimensions to be closer to 26" x 18" x 14". And while these cabinet dimensions can be off a half inch or so, be sure the port dimensions are "right on the money." You must have inside dimensions of 2.5" diameter and 2.75" long for the design to be optimal.
Re: Thanks a lot ! (nt) [message #33804 is a reply to message #33803] Wed, 05 September 2001 00:19 Go to previous messageGo to next message
nt
Good luck and keep us posted! [message #33807 is a reply to message #33804] Wed, 05 September 2001 04:44 Go to previous messageGo to next message
AudioLapDance is currently offline  AudioLapDance
Hi Observator,
Hey, who you lookin at! ;-)
I built Thorsten's Afterburner but am now going to try the Beta12LT in a PI cabinet.
Thorsten used an Extended Bass Shelf alignment (EBS) which is in the oposite direction compared to Wayne's alignment. It should make a nice comparison.
Do you have the Rat Shack tweet? I found them too bright--could be too sensitive or the 1st order crossover isn't attenuating quickly enough so there's too much overlap at 8-10kHz.
I'm going try a piezo tweet with a second order crossover.
Good luck and please let us know how it goes,
Cheers,
Jeff
Re: Good luck and keep us posted! [message #33808 is a reply to message #33807] Wed, 05 September 2001 05:23 Go to previous messageGo to next message
Hi Jeff,
> in a PI cabinet.
From my side, I was inspired by reviews about hammer dynamic
super12. I haven't possibility to hear it, so i decided first
to build afterburners for having an idea how 12" FR performs.
what's your opinion ? Can you compare it with something I
know ;-), let say FE103 or 40-1354 or FE208s....
what's also your amplifier ?
Thanks for your advice, i haven't possibility to buy RS tweeter
here so I had the same idea as you - Motorola piezo. Which one
is your favorite ?
And, what about adding a low-pass and zobel for beta12tl same as
used in super12 ? This could be a solution to clarify the 10k region.
> Cheers,
> Jeff
thanks, I will do
O'Tor
Re: Beta 12LT in PiAlign'ed cabinet [message #33920 is a reply to message #33803] Wed, 26 September 2001 09:10 Go to previous messageGo to next message
Hi Wayne,
I just verified this calculs and unfortunately this doesn't work
for me. In your whitepaper for the port calculation I read:
Fre = 1/(2*pi)*(Ap/(Ve*Lc))^(1/2)
If Dp=2.5 and Lp=2.75, then Lc= 4.87,
if Dp=2.5 then Ap=pi*(Dp/2)^2 = 4.91,
and then for Ve=2.4 i have
Fre = 0.10312
and not 33.75 Hz as you said.
(Qe = 1.54 with no problem)
What's wrong ?
Thanks in advance,
O'Tor
Re: Beta 12LT in PiAlign'ed cabinet [message #33962 is a reply to message #33920] Fri, 28 September 2001 15:15 Go to previous message
You used 2.4 as as cabinet volume but you should have used 2.4 x 1728 to convert it to cubic inches. You must use the same terms throughout - If inches in one place then inches must be used everywhere. You can use feet if you wish, but then the port dimensions must be in feet for "Lc" and sq. feet for "Ap".
Previous Topic: Port length on multiple ports
Next Topic: XO-slope for sub
Current Time: Fri Nov 13 05:39:14 CST 2026
