Home » Sponsored » Pi Speakers » Questions before I jump in
Questions before I jump in [message #33764] Fri, 31 August 2001 15:01 Go to previous message
I'm considering construction of either the 3Pi theater, or the 4Pi pro. In my listening room, speaker placement would have to be on either side of a fireplace, and directly in front of windows (the floor to celing windows flank the fireplace). My listening position will be about 10' away on a couch that is right up against a wall. The room is about 14' x 18', and vaulted 15' celings. The question is, will the speaker location work for Pi speakers, if so, how far from the windows should they be? Also, should the speakers be on stands so the tweeter is at ear level? Last, could anyone comment on the sonic quality of either/both of these? FWIW, I listen to jazz, classical and some rock with SE amps using 300B's (8-10 watts). Thanks for the input.
Steve
Previous Topic: eldragon, this review's for you
Next Topic: changing my mind - want to build pi 7's
Current Time: Wed Oct 21 22:27:31 CDT 2026
