Home » Sponsored » Pi Speakers » ZMAX figure for very low damping factor amplifiers
ZMAX figure for very low damping factor amplifiers [message #33694] Wed, 15 August 2001 08:39 Go to next message
Super_BQ is currently offline  Super_BQ
I've been told to look for a woofer that has very low ZMax figure.
What range of ZMax figures should I be looking in 15" or 18" woofers? What trade-offs are there to using an extremely low ZMax figure? I see the cheaper models of woofers have a lower ZMax figure and the more expensive flashy ones have a high figure.
The amplifier I plan to use has a damping factor similar to SET or other tube amplifiers. Power i'm driving is 25 watts x 2.
I vote for Delta15 and Theater Seven Pi [message #33696 is a reply to message #33694] Wed, 15 August 2001 10:12 Go to previous messageGo to next message
AudioLapDance is currently offline  AudioLapDance
Hey Super BQ,
I found the Delta15 is a good compromise of price and performance and with 52 ohms Zmax, it is good for tube amps too. Wayne's designs can handle a lot of power but because of their high efficiency, that's another reason they work well with low powered amps.
Ask Nelson what the output impedance of the Son of Zen is; I think it will be under 1 ohm. My Decware Zen is 0.8 ohm.
If you have the space I would go for the Theater Seven Pi.
Good luck!
Are you doing this DIY?
Jeff
Re: ZMAX figure for very low damping factor amplifiers [message #33697 is a reply to message #33694] Wed, 15 August 2001 10:41 Go to previous messageGo to next message
Of course, the cabinet will modify the woofer impedance curve substantially, but if used in a reflex cabinet, I'd still try to find a woofer with free air Zmax under 50 - 75 ohms and woofers for sealed cabinets probably should be even lower. This is important when using amps with low damping factor (high output impedance), less as output impedance goes down (damping factor up).
Re: ZMAX figure for very low damping factor amplifiers [message #33698 is a reply to message #33697] Wed, 15 August 2001 13:30 Go to previous messageGo to next message
Wayne, I like to thank you for all your help. Would building the Seven Pi - 18 Cornerhorns be worse than the 15" 7 Pi for the amp I'm using?
Re: ZMAX figure for very low damping factor amplifiers [message #33701 is a reply to message #33698] Wed, 15 August 2001 16:25 Go to previous messageGo to next message
The JBL 2241 and 2242 have relatively low Zmax - just like the 2226 does. They're all about 60 ohms at resonance in free air, which makes the in-cabinet peaks about 30 ohms. That's good for tube amps and so any of those one will work very well for you. Not only is the impedance curve pretty benign but the cabinets are overdamped, which makes them tolerant of higher output impedance and other causes of eletro-mechanical parameters shifts, such as voice coil heating, environmental conditions, etc.
Re: I vote for Delta15 and Theater Seven Pi [message #33707 is a reply to message #33696] Wed, 15 August 2001 18:17 Go to previous messageGo to next message
Hi Jeff,
I've already e-mailed Nelson Pass on the output impedance of the son of zen amp I built. unfortunately I'm visiting in Canada (and shopping) and won't be back in New Zealand for another 6 weeks. So there's no way I could even get a reading in the short time.
I'll post as soon as I get a reply from Mr. Pass.
Welcome to Canada, eh! (nt) [message #33709 is a reply to message #33707] Thu, 16 August 2001 05:09 Go to previous message
nt
Previous Topic: delta 15's in folded horns?
Next Topic: Which Pi's should I build?
Current Time: Wed Oct 21 11:49:34 CDT 2026
