Home » Sponsored » Pi Speakers » Rise in Spl with third order 11 khz high pass around 5.5khz
Rise in Spl with third order 11 khz high pass around 5.5khz [message #33624] Wed, 01 August 2001 17:23 Go to previous message
Lothar is currently offline  Lothar
Hi Wayne and forum,
Wayne put me on track with some experimenting with piezo's.
I am using two paralell ksn 1005 piezo's together with a tannoy
cheviot speaker with the HPD 315 dual concentric unit.
The goal is giving some air to the upper octave somewhere between
10 and 20 khz.
First I asked Wayne for the value of the cap in creating a first order
high pass filter starting at prox. 20 khz.
Stimulated by the results I calculated a third order high pass, starting at prox. 11khz.
Setup: 20 ohm resistor paralell to the 2 piezo's, 1.5 ufd in series,
.22 coil to mass and then .49 ufd in series again.
Not altogether unsatisfied with the sonic result (It really gives
"some air"), I connected a sinus generator to the amp and gave it a
sweep.
I put a radio shack Spl meter in front of the Piezo's so that
I also had some visual control over what I was about to hear.
Well, to come to the point, I was a bit disapointed about the output
above 16 khz and, most important, I noticed a sharp audible and
measurable increase in output sharply around 5.7 khz.
In fact, according to the spl meter, the output was somewhere around 5 db higher then on 12 khz.
And that after I thought I am using a third order 11khz high pass!
Is it possible that I have to use something that is called a notch
filter?
Well Wayne and the rest, I hope that you have some time for a sugestion.
Robin.
Previous Topic: Horn equalization
Next Topic: delta 15's in folded horns?
Current Time: Wed Oct 21 07:25:44 CDT 2026
