Home » Sponsored » Pi Speakers » wayne, check these woofers out
wayne, check these woofers out [message #33417] Wed, 13 June 2001 17:29 Go to next message
hi wayne, i just purchased a surplus of eminence 15" woofers. look at the specs and see if they will work with any of your designs?
15" H.P SUBWOOFER
ACCORDIAN CLOTH SURROUND
3" KAPTON VOICE COIL-4 LAYER
95oz ceramic magnet
Re(ohms) 4.80 Fs(Hz) 38.52
Le(mH) 1.10 Mms(g) 92.80
Qm 8.82 Cms(mm/N) .1840
Qe .470 Rms(Ns/m) 2.5464
QT .450 Vas(L) 189.55
Xmax(mm) 4.80 Sd (cm^2) 856.34
BL(Tm) 13.59 EBP 82.00
EFF(%) 2.22 SPL(dB) 95.50
the story behind these are that they were made for klipsch but the impedance posed a problem, anyhow those on the forum who want some can have them for $80.00 a piece.
thanks, george
Re: wayne, check these woofers out [message #33418 is a reply to message #33417] Wed, 13 June 2001 23:02 Go to previous message
From the looks of the numbers, I think those woofers would work pretty well in the Theater Series six Pi cornerhorn, with the woofer hole cut to fit, of course. Depending on how well damped cone flex is through the midrange, it might work well in the Theater three Pi too.
Previous Topic: My Sincere regards to Waynes Family
Next Topic: Pro Series 4 Pi questions.
Current Time: Mon Oct 05 14:08:37 CDT 2026
