Home » Sponsored » Pi Speakers » Any thoughts about the Peavey 22XT?
Any thoughts about the Peavey 22XT? [message #33372] Tue, 22 May 2001 21:49 Go to next message
Bridgetown is currently offline  Bridgetown
I am about to start building my Pi7 horns, recently received the plans recently from Wayne. I have a pair of Peavey 22XT compression drivers. I have not seen any discussion about Peavey 22XT in the forum and I am not sure if this driver would make a suitable as high frequency unit for the Pi7.
The specifications are as follows:
Throat parameter: 1"
Nonimal impedenance: 8 ohms
Sensitivity : 111dB SPL 1w/1m on a CH-2 horn
Frequency range: 500-20,000 Hz
Frequency range: +/- 2dB 500-3,200 Hz, -3dB@8,000 Hz
6dB roll off from 8,000-20,000 Hz
Diaphragm: titanium
Power capacity : 40 watts
I would appreciate any comments regarding its suitability and possible compensation network.
Regards
Re: Any thoughts about the Peavey 22XT? [message #33373 is a reply to message #33372] Tue, 22 May 2001 22:55 Go to previous messageGo to next message
Do you happen to have response measured on a plane wave tube?
Re: Any thoughts about the Peavey 22XT? [message #33374 is a reply to message #33373] Wed, 23 May 2001 00:18 Go to previous messageGo to next message
Wayne
Thank you for your response to my post. No, I don't have any measurements but maybe they are published somewhere. I am living in Barbados and I purchased the components from a pro audio shop locally.
Re: Any thoughts about the Peavey 22XT? [message #33375 is a reply to message #33374] Wed, 23 May 2001 08:16 Go to previous messageGo to next message
I have used the Peavey 22XT, along with Peavey CH3 horn lens, and they are very good.
Re: Any thoughts about the Peavey 22XT? [message #33440 is a reply to message #33375] Thu, 21 June 2001 19:57 Go to previous message
By the way, the 22XT sounds a lot like the Eminence 1" drivers. I'd say it's probably about an even match.
Previous Topic: Theater Seven Pi--so far so good!
Next Topic: Where to buy JBL2426 diaphrams?
Current Time: Thu Nov 19 12:08:16 CST 2026
