Home » Sponsored » Pi Speakers » Piezos / 2 way designs
Re: Thanks, you make a very strong agument for this driver! [message #33345 is a reply to message #33343] Fri, 11 May 2001 18:12 Go to previous messageGo to next message
My Pyles are some older models, MH1560, no longer catalogged, at least not under that number. These are 15" musical inst / PA woofers.
I have used these in several cabinets and with several horns. But the easiest to use, by far, are the CTS-Motorolas.
The 1188's I have sound very good. Yes, I wish I had a response graph to look at, but my ears tell me they are just fine.
According to what I found on the CTS site, and talking to Mr. Moleski today, wire a 20 ohm 10 wt resistor in series with the 1188's. The 1188's also have the same Powerline protection circuit as the KSN1165, 1142, etc. The various 1800 hz Powerline drivers need no outboard resistors, or other parts of any sort.
Re: Thanks, you make a very strong agument for this driver! [message #33347 is a reply to message #33345] Sat, 12 May 2001 22:53 Go to previous messageGo to next message
Crazy Dave is currently offline  Crazy Dave
If you wired a 20 ohm 10 wt resistor in series, wouldn't it attenuate the output of the driver? I thought that you would want it parallel (across the terminals). Note that I don't have any experience with piezo drivers.
Dave
Re: Thanks, you make a very strong agument for this driver! [message #33348 is a reply to message #33347] Sun, 13 May 2001 01:58 Go to previous messageGo to next message
"If you wired a 20 ohm 10 wt resistor in series, wouldn't it attenuate the output of the driver?"
The 1800 hz drivers (KSN1025a, KSN1165a, KSN,1141, KSN1142a)already have a 22 ohm resistor already built in, in series...I think that is the value, it has been a while since I tore into one. They need no outboard parts for protection. CTS advises adding a 20 ohm, 10 wt resistor in series with the larger KSN1188a (800 hz horn driver). The piezos have such a high impedance in their response range, 20 ohms is nothing. There is no noticable drop in output in audible range.
But what happens is that way up high, 30khz and higher, the impedance drops very low... a piezo acts like a capacitor, not a resistor. A 20 ohm resistor in series gives the amp some load. If you have some stray signal, or occillation, with an amp that can respond up to 100 khz, as modern amps can, then you will have a problem.
So, the resistor protects the piezo (and the amp, too) at those very high, inaudible frequencies.
The only reason I ever wire a resistor across the terminals... I have used an 8 ohm 20 wt resistor across the terminals to make it act, to a crossover, as if it were an 8 ohm dynamic driver. Then you can put an appropriate cap in series with it, and cross it over at a higher frequency if desired. Or you can put an L-pad between the cap and the now "8 ohm driver".
Try this experiment... hook some wires to your amp's output and connect them to the terminals of a piezo driver. No other parts. Put on some interstation FM hiss, white noise, whatever. Now, get your 8 ohm resistor, and touch it across the terminals (parallel)... hear a difference?
OK, now wire a 20 ohm resistor in SERIES with the piezo driver, turn on some noise and listen. Use a piece of wire to short around the resistor. Hear a difference? You won't.
I don't usually attenuate the piezos... I just chose a woofer that is in the 95-98db SPL range. Plenty of those available.
Re: I hope everyone interested in piezos reads this whole thread [message #33349 is a reply to message #33348] Mon, 14 May 2001 11:25 Go to previous messageGo to next message
Paul,
You have given quite a lot of useful information on these drivers. The DIY press usually ignores the subject of piezos. I have gotten a great deal of information on what I considered a "hidden art" before these posts. Your posts have taken me a lot further in understanding these interesting drivers.
Piezos are a natural for the DIYer. They are simple, cheap, and rugged, have a wide frequency response and don't require a crossover. What’s not to like?
Please post the values of the inductor for the woofer on the 800Hz driver (when you get you system fine tuned). Let us know when you get any more interesting data.
Dave
Re: I hope everyone interested in piezos reads this whole thread [message #33350 is a reply to message #33349] Mon, 14 May 2001 12:47 Go to previous messageGo to next message
Dave: You will like this... my home stereo spkrs are some SpeakerLab designs nearly 20 years old. This system is 2 cft sealed, 10" woofer, 3" Audax cone midrange, and the little 10mm dome Polydax tweeter. Crossover was 800/6000 12 db all the way. 92 db SPL and F3 = 40 hz. Well, I had replaced one of the mids about 10 years ago, Audax said they were no longer in production, and steered me to Madisound, where I got the last one on the shelf. So, replacing those was out.
I blanked off the midrange hole, took out wire cutters and hacked out the crossover... what a pile of parts! I put in a zobel for the woofer, 10 ohms + 17 uf in series across the terminals, and a .7 mH inductor in series... a simple 6db at 1800 hz or so. I installed KSN1165a's in place of the tweeters, with an 8 ohm resistor across the terminals, to make them look like an 8 ohm driver to my meager crossover. I wired the 1165 and resistor to the L-pad, and from the L-pad back to the hot lead a 12 uf cap. I dialed the L-pad down about -5 to sound right with the woofer.
These speakers never sounded so good.
I will be using the KSN1196a 5x15 horn lens and KSN1188a 800 hz driver with only a 20 ohm resistor in series with the piezo, and 1.5 mH inductor in series with my older Pyle MH1560 woofers (15", 60 oz mag, 97 db SPL...) and exact box design not determined yet. I formerly had the Pyles in a 6.3 cft ported box with a Pyle H3910E horn crossed at 2500 hz 12 db/oct.
I am sure the 800 hz horn assembly will give better dispersion and sound better as it will carry more of the midrange.
Re: Sounds great! It may be getting time for me to break out the table saw. NT [message #33351 is a reply to message #33350] Mon, 14 May 2001 13:44 Go to previous messageGo to next message
No text.
Re: Sounds great! It may be getting time for me to break out the table saw. NT [message #33353 is a reply to message #33351] Mon, 14 May 2001 16:39 Go to previous messageGo to next message
The Pyle MH1560's (and there are comparable newer models available now, PYM1555, PYM1578, PYM15128) and KSN1188a combo will be for PA use. Wayne assures me these Pyles will give good performance in a large touring horn arrangement.
Re: Piezos / 2 way designs [message #33354 is a reply to message #33335] Mon, 14 May 2001 17:09 Go to previous messageGo to next message
DJ Z is currently offline  DJ Z
Excellent articles, and right on time. I have just ordered a couple of piezos and will be bookmarking all this info.
Re: Sounds great! It may be getting time for me to break out the table saw. NT [message #33355 is a reply to message #33353] Tue, 15 May 2001 09:15 Go to previous messageGo to next message
Parts Express:
PYM1555 292-236 300W 95.8db $59.90
PYM1578 292-238 400W 97.5db $79.90
PYM15128 292-240 600W 96.6db $139.75
Assuming that the 800Hz Piezo can keep up with 97.5 db (1w/1m) efficiency, the PMY1578 looks like the deal (although the aluminum basket, 4" VC w/ Kapton former, 125oz magnet, and 600W power handling capacity of the PMY15128 looks good). Otherwise, the specs on the woofers look identical.
Any idea of how Pyles would work in a base-reflex home installation? I know there are people who swear by them. I think they would perform well using Wayne's alignment (early, shallow roll-off).
What kind of impedance load do you think a system like this would present? Could it be smoothed out enough for vacuum tubes or is this a transistor only system?
Dave
Re: Sounds great! It may be getting time for me to break out the table saw. NT [message #33356 is a reply to message #33355] Tue, 15 May 2001 11:23 Go to previous messageGo to previous message
Dave: I have used earlier Pyles (MH1560) in bass reflex speakers, and they worked just fine. Boxplot (and I will send you a plot I ran on these three) looks good, too. The 1188's are about 96db, and the woofers you list at 97.5 db SPL, you are only talking 1.5 db difference... hardly worth worrying about.
I just ran the 1578 specs thru BoxPlot for my brother, and with a 5 cft ported cabinet, F3=52 hz, two 3" dia x 3.2" long ports. With 8 cft you can get down to about 45 hz.
The 15128, in a 5.14 cft box, F3=44hz, 2 ports 3" dia x 1.61" L. The 96.6 db SPL should match the 1188 well.
Previous Topic: Stage monitors -- doubled Pi 4s?
Next Topic: Pi implementations of quartz piezoelectric tweeters
Current Time: Tue Nov 03 07:37:38 CST 2026
