Home » Sponsored » Pi Speakers » piAlign software and figuring Zmax
piAlign software and figuring Zmax [message #33248] Fri, 27 April 2001 11:06 Go to previous message
juanstein is currently offline  juanstein
Hi Wayne -- I have been experimenting with your piAlign program and a few different drivers. I looked at the TAD 1602, but that was a huge cabinet solution. The TAD 1601c at 102 dbW/m turned out to be a very attractively sized enclosure.
I have a few details I was interested in having explained. The dimensions generated seemed to follow a 1 x 2 x 4 pattern, therefore, to compensate for internal displacement of physical objects inside the cabinet, such as the magnet and basket, and whatever cross-bracing is there, do you simply keep the 1/2/4 ratio and increase the dimensions until the additional volume is accounted for? Is the volume enclosed by the vent structure and inside the vent already included in the box dimension calculation, or is that another volume that must be added back into the cabinet dimension?
Can you find Zmax from mechanical parameters? Thanks for any clarification (I have more questions for another thread).
John
Previous Topic: wayne, you da man!!!!!
Next Topic: Anybody have some Pi's in the SF bay area they want to show off to me?
Current Time: Sat Nov 07 01:33:36 CST 2026
