Home » Sponsored » Pi Speakers » Eminence changes posted
Eminence changes posted [message #33123] Sat, 31 March 2001 23:27 Go to next message
The Pi Speakers web site has been changed to reflect Eminence's new 2001 product specifications. If any of you require the 2000 model specs, please let me know and I'll E-Mail them to you privately.
Most of the products were not changed, and specifications reflected either no change or only a insignificant fractional change - well within tolerance. Of those that had relatively significant changes, some should be considered to be improvements but most were probably mistyped or incorrectly calibrated measurements. For example, some motors listed relatively high Xmax, but Qms was fairly low. In these cases, Xmax is shown to be a more reasonable figure while Qms changed very little.
The consequence of these changes is minimal - most designs that were optimal for a 2000 model driver are also optimal for the corresponding 2001 version. Notable exceptions are the Alpha 15 and the Omega 12. The Alpha 15 will require a different cabinet and the Omega 12 will require a different crossover.
Below is a chart showing the differences between the 2001 models and their 2000 counterparts:
Motor Where used "Tube friendly" (y/n) Xover change (y/n) Cabinet change (y/n) Significant Change
Alpha 8 Studio 1 Pi Y N N Qms
Alpha 10 Studio 2 Pi Y N N
Alpha 12 Studio 3 Pi Y N N
Alpha 15 N/A (opt 4 Pi) Y N Y Vas
Beta 8 Premium 1 N N N
Beta 10 Premium 2 N N N
Beta 12 Premium 3 N N N
Beta 15 Premium 4 N N N
Delta 10 Theater 2, 5 N N N
Delta 12LF Theater 3, 6 N N N Vas and Qms
Delta 15 Theater 4, 7 Y N N
Omega 12 N/A (opt Stage 3, 6) N Y N Vas and Le
Omega 15 Stage 4, 7, 10 N N N
Omega 18 Stage 4-18, 7-18, 10-18 N N N
Kilo 15 Premium Stage 4, 7, 10 N N N
Kilo 18 Prem Stage 4-18, 7-18, 10-18 N N Vas
Re: Eminence changes posted [message #33133 is a reply to message #33123] Mon, 02 April 2001 18:57 Go to previous messageGo to next message
bcherry is currently offline  bcherry
You list the Beta 12 as being tube unfriendly but according to the Eminence site the Zmax of the Beta 12 series ranges from about 78 to 94 ohms. Is there another reason?
bcherry@diyhifisupply.com
Re: Eminence changes posted [message #33134 is a reply to message #33123] Mon, 02 April 2001 19:03 Go to previous messageGo to next message
Well, I see below that your recommended cutoff for Zmax and tubes is 50 ohms. How bad is the 75-90 ohm range going to be?
"Zmax" - Impedance at Resonance [message #33135 is a reply to message #33134] Mon, 02 April 2001 21:33 Go to previous messageGo to next message
There are two loudspeaker criteria that are important for SET owners in addition to the usual matters of sound quality. One is efficiency and the other is impedance. You need high efficiency because amplifier power is limited and impedance peaks should be as small as possible because amplifier output impedance is fairly high. If there are big peaks in impedance, they will interact with the amplifier and be manifested as peaks in response.
Very informative, thanks. (nt) [message #33136 is a reply to message #33135] Mon, 02 April 2001 23:00 Go to previous message
Jack Gilvey is currently offline  Jack Gilvey
Previous Topic: Humorina in Odessa!
Next Topic: theater 7 x-over
Current Time: Mon Oct 19 21:39:08 CDT 2026
