Home » Audio » General » Help rearrange this room
Help rearrange this room [message #3246] Thu, 08 June 2006 12:01 Go to next message
Ok, my wife is going to have me rearrange the living room again (every 3 months ). Here is a quick and dirty drawing of our layout as it stands. I could use some help with some tips for optimum speaker placement. Obviously we are dealing with asthetics here as well. Right now I have the Heresy's about 5.5' apart and 16" off the wall on either side of the entertainment center. It's the EC that can be troublesome. 5' wide, 16" or so deep and 4.5" tall. I can't imagine it's not causing some problems.
Re: Help rearrange this room [message #3247 is a reply to message #3246] Thu, 08 June 2006 14:10 Go to previous messageGo to next message
My suggestion is that you check out your options with CARA.
Re: Help rearrange this room [message #3248 is a reply to message #3247] Thu, 08 June 2006 14:25 Go to previous messageGo to next message
Is it the whole software bundle you need?
Re: Help rearrange this room [message #3249 is a reply to message #3248] Thu, 08 June 2006 14:28 Go to previous messageGo to next message
Yes, it's fairly inexpensive. Less than a hundred bucks.
Re: Help rearrange this room [message #3250 is a reply to message #3248] Thu, 08 June 2006 14:34 Go to previous messageGo to next message
Well worth the money!!!
Re: Help rearrange this room [message #3253 is a reply to message #3246] Thu, 08 June 2006 17:08 Go to previous messageGo to next message
charlieboy is currently offline  charlieboy
Well depending on how much "play" you have with speaker placement it looks like your around 12' away so I would pull them out from the wall more and spread them out a little more. I have Heresy's also and I cant hardley listen to them without a sub.
Re: Help rearrange this room [message #3254 is a reply to message #3253] Thu, 08 June 2006 19:26 Go to previous message
Unfortunately, the EC can only go on the wall it's on or the long wall on the left. Where the speakers are at now: if you pull them out too much more they're right in the walkway from the kitchen doorway on the left to the sliding glass doors to the patio on the right. The dorrway on the left is also the main one to the bedrooms. It's such a nice big room, but a big lousy layout. I swore to my wife someday I'll have a room for just my audio and music!
Thanks for the suggestions. The Heresy's sound all right to me. They could probably use a sub, but since I've never had speakers that weren't bass challenged in some regard, I guess I don't really notice.
Previous Topic: Hear the evil, see the evil
Next Topic: Kewl Crossovers
Current Time: Fri Nov 13 07:15:47 CST 2026
